  • 277 Vote(s) - 2.84 Average
140 degree automated gates
(28-01-2013, 10:49 AM)Mark Wrote:
(25-01-2013, 06:06 PM)firehelm100 Wrote: I have a query.
we want a set of gates to open to 140 degree we do not want to use underground gate rams. We want to use spider rams which open to 110 degree. IF we offset the spider rams further away from the gate post will we be able to get them to open to 140degree if we offset them in the correct place.
regards
lewis
I don't think there is an Arm Available that will give you an opening much more than 110 degrees. The Only solution for 140 degree opening would be Underground motors.
As an arm Pivots and the Geometry determines the angles that can be achieved it is very important you do not fit an arm outside its recommended geometry. This will cause damage to the arm and brackets as the arm will be pushing and pulling beyond its limits and in theory will be fighting against itself. The Max you can usually get with any Arm type automation is 120 degrees.
Hope this has helped with your questions
Hey, Thank you for your reply. We have now found a solution which means we can open to 130 degrees using articulated electric gates. There is a system specificly designed for wide angles.
But thank you for your input.
Kind Regards
Lewis
140 degree automated gates - by firehelm100 - 25-01-2013, 06:06 PM
RE: 140 degree automated gates - by Mark - 28-01-2013, 10:49 AM
RE: 140 degree automated gates - by firehelm100 - 28-01-2013, 11:15 AM
  Gates not staying open JimM169 1 2,790 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,479 21-08-2024, 12:21 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 10,273 04-05-2024, 12:41 PM
  Gates tripped Phil.c 3 6,166 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 3,095 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,143 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,046 07-01-2024, 07:11 PM
Last Post: Simon NW
  Gates Opening After Closing tht7 2 15,702 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 30,505 23-02-2023, 01:08 PM
