  • 279 Vote(s) - 2.84 Average
Wiring relay to CB24
(18-07-2012, 10:38 PM)magga Wrote: Hi everyone,
I have some SCS300K 24v openers, and am looking at getting the following:
http://www.lightwaverf.co.uk/LightwaveRF...LW821.html
How would I go about wiring this up to the CB24 board? I assume it would be wired a similar way to a key switch etc?
The wiring instructions for it can be found here:
http://www.lightwaverf.co.uk/files/downl...0Relay.pdf
Thanks!
What are you trying to do with this device. Do you want it to open and hold open your gates or just to control gates. Tjis is not an ideal solution as this is a latching reciever ie it switches on then stays switched on untill triggered again or timmer is set so if used to control the Cb24 the gates would open and hold open untill you trigger the device again.
Wiring relay to CB24 - by magga - 18-07-2012, 10:38 PM
RE: Wiring relay to CB24 - by Mark - 20-07-2012, 10:34 AM
RE: Wiring relay to CB24 - by magga - 20-07-2012, 12:06 PM
RE: Wiring relay to CB24 - by Mark - 23-07-2012, 09:42 AM
RE: Wiring relay to CB24 - by magga - 01-08-2012, 06:35 PM
  CB24 delay to close random fault stuartdsutton 0 10,181 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,673 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,461 20-08-2012, 09:40 AM
  cb24 photocells devonaloan 1 13,563 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 18,965 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Problems andydday 3 22,232 06-02-2011, 11:39 AM
Last Post: Guest
  CB24 Kit with a single set of photocells JD1765 1 22,964 07-06-2010, 10:04 AM
  CB24 / EasyBKA cliff finch 2 17,810 25-03-2010, 09:25 PM
Last Post: cliff finch
  CB24 Stopped Responding TimL 5 29,096 19-11-2009, 05:22 PM
Last Post: adambrown81
  Wiring Photocells on the CB11 control board Sparky 2 25,661 28-06-2009, 10:19 PM
Last Post: Sparky
