  • 468 Vote(s) - 2.91 Average
CB24 Stopped Responding
I have LYN300 Gates Openers and Liftmaster CB24 Control unit and up and until now been extremely happy. However, over the weekend they have just stopped responding to the remotes - All 3. I have tried the following, removed / replaced all batteries (on remotes) along with trying to re-program the key fobs with the control unit. The control unit appears to be fine (power etc) however will not pick up any of the key fobs now.
Any advise would be greatly appreciated. Thank you
Hi Tim
When you press your fobs do you hear the relays clicking on the control board ?
have you checked your photocells ?
Sparky Wrote:Hi Tim
Sparky Wrote:Hi Tim
Hi Sparky, thanks for your response. I can confirm the relays are not clicking (am familiar with what you mean). Not sure about the photocells?
Thanks,
Tim
Delighted to say CB24 Control Panel and Automatic Gates are now responding and fixed.
Big "Thank you" to Mark @ Easygates for talking me through a series of checks : checking fixing for aerial and reseting panel by removing all power Inc Back Up Batteries - After which the unit jumped back into life.
Well done Easygates.
Tim
Hi Everyone,
I just gone through the entire post thanks for your suggestion i also facing the same problem as CB24 Stopped is not responding,well due some of the suggestion in the forum i had solved my problem
  CB24 delay to close random fault stuartdsutton 0 10,174 23-09-2015, 11:38 AM
Last Post: stuartdsutton
Rolleyes Chamberlin Liftmaster Professional (CB24 & dual LYN400.24v) SDL 4 33,658 29-12-2013, 02:26 PM
Last Post: Tussun
  Liftmaster Professional CB24 / LYN400 24v - RPM Reversal Error jrhodes310 1 15,450 20-08-2012, 09:40 AM
  Wiring relay to CB24 magga 4 25,553 01-08-2012, 06:35 PM
Last Post: magga
  cb24 photocells devonaloan 1 13,559 28-11-2011, 05:57 PM
  Liftmaster CB24 key switch Mel1962 2 18,954 25-10-2011, 09:52 PM
Last Post: Mel1962
  CB24 Problems andydday 3 22,214 06-02-2011, 11:39 AM
Last Post: Guest
  CB24 Kit with a single set of photocells JD1765 1 22,955 07-06-2010, 10:04 AM
  CB24 / EasyBKA cliff finch 2 17,795 25-03-2010, 09:25 PM
Last Post: cliff finch
  CB24 - Intercom Release 1 13,713 22-04-2009, 04:11 PM
