  • 331 Vote(s) - 2.78 Average
Changing the gate code
Hi Paul,
On the gate system you have, I would reccomend to clear the memory on the receiver. This will be located in the control panel down by the gates. You do this by going by the following instructions:
01. Press and hold the receiver key and check the following
changes in Led status:
– (after approx. 4 seconds) the green led illuminates;
– (after approx. 4 seconds) the green led turns off;
– (after approx. 4 seconds) the green led starts flashing.
02. At this point release the key exactly......
• on the 3rd flash, to delete all transmitters, or,
• on the 5th flash, to delete the entire memory of the
receiver, including configurations and encoding families of
the transmitters.
Once this procedure has been done you can reprogram your existing remotes by pressing the programming button on the receiver for around 2 seconds and releasing, then press the button on the remote you wish to use. The other button on your remote is just used in the case of any more NICE automation being added to your property. In this instance you would be able to program one button to operate your automated gates and the other to operate, say a garage door opener.
Hope this helped!
Dave Blake
Dave Blake
Changing the gate code - by paulthegman - 27-03-2012, 12:39 PM
RE: Changing the gate code - by Blakey111 - 27-03-2012, 03:08 PM
RE: Changing the gate code - by paulthegman - 27-03-2012, 03:21 PM
  Youtube gate specialist broke my module Harvie C 2 1,511 11-11-2025, 03:23 PM
  Can a Hormann Bisecur learn a code from a Nice ON2E? ? Noghar 1 5,713 17-07-2024, 02:21 PM
  BFT Gate Motor CDG 1 4,370 11-06-2024, 09:09 AM
  Gate stuck after opening. rixman 4 8,428 11-04-2024, 08:10 AM
  Replace receiver nice gate Mebeaker 2 10,792 29-03-2021, 03:42 PM
Last Post: Mebeaker
  wifi gate opener xjust 0 6,381 13-02-2021, 10:42 PM
Last Post: xjust
  Wifi Gate Opener - IT4WIFI problems Mehullakhani 0 10,311 12-08-2020, 11:10 AM
Last Post: Mehullakhani
  Aria gate openers and GSM controller Jamie 2 10,285 25-04-2020, 06:19 PM
Last Post: Jamie
  Nice TOO 3000 Gate opener not closing Sully 1 11,326 17-03-2020, 11:34 AM
