  • 324 Vote(s) - 2.82 Average
Proteco RX3 Remote programming
Sad
I fitted at Easter a Proteco Q60A control unit with TX3 remote's, the remote's have worked for about 8 weeks but then both just stopped working, from this I assume the remote's are OK and the fault is with the control unit.
I have checked the readout on the unit and it still retained the programmed remote's in It's memory, I wiped off the remote's from the memory and attempted to re-program, the unit would not be re programmed as when I select rA then tc I then press the remote button, I should get a dot on the readout but nothing appears so there is no point in pressing button C to store, but I have tried it without just for piece of mind.
No broken wires.
The beams and key pad still operate the unit .
Has anyone had this problem or should I just replace the board.
I have re booted the unit and checked the internal fuses, but no difference.
Help...Dave C.
Proteco RX3 Remote programming - by davec. - 16-06-2010, 12:15 AM
RE: Proteco RX3 Remote programming - by Mark - 29-06-2010, 04:52 PM
RE: Proteco RX3 Remote programming - by Guest - 09-02-2011, 11:05 AM
  Two BFT pairs of electric gates (one remote) Harry44 1 4,540 04-06-2024, 01:30 PM
  Set remote to “only open” gate mark123499 4 10,416 30-05-2023, 01:57 PM
Last Post: mark123499
  Remote only working close up Uphill 0 5,936 03-10-2021, 07:50 PM
Last Post: Uphill
  BFT Deimos Ultra remote problems shaggy 1 14,847 01-05-2019, 09:43 PM
Last Post: ok.dude
Question BFT MITTO REMOTE Battery mk1984 0 10,492 14-11-2016, 01:35 PM
Last Post: mk1984
  Can attempt to add remote but does not open gates conchiron 2 20,889 16-10-2016, 01:31 PM
Last Post: conchiron
  Remote control never detected by Rigel 5 guyvaio 0 8,377 18-06-2016, 06:17 PM
Last Post: guyvaio
  connect Remote control to Arduino dentalan 4 27,903 30-12-2013, 09:17 PM
Last Post: tommysharp
  BFT Barrier Programming EIMB28 4 27,658 24-01-2010, 11:21 PM
Last Post: BarkerandGeary
