  • 303 Vote(s) - 2.9 Average
The legnth of the leaf is very important. For the size of each leaf being 2.5m you would require the SUB ER motors. The boxes you have already installed would be compatible. The SUB ER motors will be quite alot slower than the SUB R motors. They are also non-locking so security will be an issue as you can force the gates open.
With these non-locking motors, the seals will not break and should last a long time with regular service.
We can get these motors ordered in for you if you require them
If you need any more details please call us on 0845 054 50 70 and ask for Technical.
(13-04-2010, 06:44 PM)jgpp Wrote: Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
Gate automation failure/ replacement - by Guest - 11-04-2010, 07:10 PM
RE: Gate failure/ replacement - by easygates - 13-04-2010, 02:35 PM
RE: Gate failure/ replacement - by jgpp - 13-04-2010, 06:44 PM
RE: Gate failure/ replacement - by easygates - 15-04-2010, 02:01 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 778 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,871 09-01-2026, 10:03 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,510 11-11-2025, 04:41 PM
  I want to know Best Gate Lock for Security? mitasali 0 5,097 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,666 18-03-2025, 06:40 AM
  Gate kit recommendation electric gate harry 0 4,177 10-09-2024, 03:57 PM
