09-01-2026, 10:03 AM
(10-10-2022, 09:58 AM)j1000 Wrote: Hi Joe,
Appreciate any advice.
Thank you for coming back to us on this.
I would try firstly getting the fault to occur again, as soon as the fault occurs due to it being a time sensitive thing have a look at the control board inside your motor.
There will be a terminal block labelled as BUS, BlueBus or ECSBUS. Behind that terminal there will be an LED flashing, under fault conditions the LED will flash a certain amount of times and pause for one second, could you let me know how many times your LED flashes as this could give us some indication of what the panel may be suggesting the fault is.
EasyGates Trade Store for Trade only
