  • 21 Vote(s) - 2.95 Average
NICE gates open slightly then stuck
(11-05-2025, 07:24 PM)Overthefence Wrote: Hi
I had NICE swing gate motors installed a few years ago and they worked fine for a month or so before one time when given the open command,  the lead gate opened a few inches and then stopped. Sending follow up close commands, open commands, using the fob, using the sms commands all failed to get any response.
The only way I could find to get them moving again is to turn off and back on at fusebox. And then the close commands would usually work. And then it’d be back to working for another month or so before the same problem happens again. Obviously always happens at the worst time and then have to scramble for the tool to release the gates.
I’ve now stopped using them as the inconsistency is a pain but would love to find a solution.
In case it helps- the kit was installed brand new and the sensors have been kept clean.
Any help would be hugely appreciated
On the Nice control boards there is a diagnostic light at the Bluebus terminal that will flash so many times to indicate what the issue may be, from the description of the fault it sounds as if the motors are force reversing, seeing more resistance than they should. If you want to contact us on technical@easygates.co.uk we will be able to better diagnose what the problem may be and offer you a solution.
Jake
RE: NICE gates open slightly then stuck - by Jakedugmore - 21-05-2025, 10:54 AM
  Nice LFAB occasionally failing open DaveHG 3 10,085 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,359 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,041 17-06-2025, 11:25 AM
Last Post: HarrisonN
  Nice Robus 250 HS Fuse Problem GLM 1 4,825 09-05-2025, 01:07 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,916 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 8,366 10-12-2024, 10:31 AM
Last Post: dmrgate
  Nice O-Box Software Andruelectricgates 1 4,739 09-12-2024, 12:52 PM
