  • 20 Vote(s) - 2.85 Average
ZLJ24 and AXO Motors gone awry
Hi mate, the first thing that I would do is swap the motor wiring outputs over as in put motor 1 in motor 2,s output then test, this way you can see the working motor on both board outputs, if the suspected good motor works on both outputs of the board during test motor mode then you know the board is OK, if a motor fails from both outputs then you can safely say that the motor is faulty. Another test is to disconnect both motors and check the resistance of the motor winding respectively. Hope this helps.
ZLJ24 and AXO Motors gone awry - by colmgillard - 08-10-2024, 08:31 PM
RE: ZLJ24 and AXO Motors gone awry - by Mibbo - 22-04-2025, 08:19 PM
  Trouble accessing ZLJ24 Control Panel Box chich 2 6,897 06-10-2024, 12:15 PM
Last Post: chich
  CAME ZLJ24 Control Panel SmtsFnd 5 11,937 08-05-2024, 08:57 AM
  ZLJ24 Reversed Paulgates 1 5,277 15-04-2024, 12:05 PM
  Came ZLJ24 Lyneve 1 7,458 16-07-2021, 12:35 PM
  Help with intercom to Came ZLJ24 paulaj 0 7,481 15-06-2020, 06:27 PM
Last Post: paulaj
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,635 02-05-2018, 06:18 PM
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,798 11-04-2018, 07:25 AM
