  • 23 Vote(s) - 3.13 Average
Nice MC824H Set Up issue
Does your board contain dip switches for motor selection? if not, you have the older model. Follow the below.
1. Press and hold down the stop (set) and the close button, until L1 starts to flash faster, then
release. Now you need to press the open or close button to move the LED to the required
LED position to select the motor type.
L1 is for motor types MB4024, MB5024 and HY7024
L2 is for the ME3024
L3 is for the TO4024
L4 is for the TO5024
L5 is for the TO7024
2. Once on the correct LED for the motor, press and hold the stop button to memorise the
motor type, then L1 should be flashing again.
3. Now complete the search for the limits. Press and hold stop and close buttons until L3 and
L4 start to flash and you should hear the panel click, then release both buttons.
4. Motor 1 should start to close and finish in the fully closed position, then motor 2 should
follow and go to the fully closed position.
5. Motor 2 should then start to open and a few seconds later motor 1 should start to open.
Both opening to the fully open position.
6. They should then both come to the fully closed position. L3 and L4 should stop flashing, L1
and L2 should flash for a few seconds and go off.
7. There should be no LEDS on at all from L1 to L8. The Bluebus light should be flashing once
per second and the ‘STOP’ Led should be on at all time
Easygates
Nice MC824H Set Up issue - by dmrgate - 04-12-2024, 10:43 AM
RE: Nice MC824H Set Up issue - by Michael - 09-12-2024, 12:47 PM
RE: Nice MC824H Set Up issue - by dmrgate - 10-12-2024, 10:31 AM
  Nice LFAB occasionally failing open DaveHG 3 10,085 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,360 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,044 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,718 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,826 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,441 16-02-2025, 05:16 PM
Last Post: gatekeeper
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,238 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,917 10-12-2024, 11:29 AM
  Potential Encoder Issue Ben_wing 1 3,923 09-12-2024, 12:57 PM
