  • 44 Vote(s) - 2.86 Average
#26
(10-05-2024, 05:19 PM)Nemen3242 Wrote:
(10-05-2024, 05:02 PM)P100D Wrote:
(10-05-2024, 04:35 PM)Nemen3242 Wrote:
(10-05-2024, 03:47 PM)P100D Wrote:
(15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Basically, I connected a hikvision relay DS-PM1-O1L-WE to the SBS contacts, I power the relay via STOP and PP as shown in the manual.  I do not understand why the opening works when I close the relay via the Hikvision AX Pro where the relay is enrolled, but it only close half a meter or something and than goes to full open again. I tried all settings in advanced settings for SBS (Open - Close - Open - Close etc) to no availability.
Thank you!
Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
I didn't need to try because my other method worked (with access controller). But this should also work. Buy it from amazon, if it doesn't work, you just return it.
Thanks so I did a little experiment, and I think I solved out all this dilemma! I connected a wire between the SBS contacts, for the opening it worked fine, and also for the closing. Then what I did next was to keep the wire there for a several seconds. Boom, the closing has the same bad behavior. My Hikvision relay pulse default was 5s for pulse, hence the issues! I lowered that to 2s, all works fine! I'm 100% you had the same issue initially going from the Hikvision door station directly to the Nice. I know because I had to replace an older Nice600, not robus, and that door station relay worked fine!
Now we can put this to rest. No need for any access control. Regardless thanks, your replay made me think twice about certain things...
RE: Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help - by P100D - 10-05-2024, 05:38 PM
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 780 09-01-2026, 10:38 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,512 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,510 09-05-2025, 12:36 PM
  Nice wingo 5400 and MC800 engrbhadz 0 2,322 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 14,210 02-12-2024, 10:40 AM
Last Post: bing
Last Post: thronetm
  Robus Not Operating AlanWhite 3 17,130 11-09-2024, 05:00 AM
Last Post: Lee Zhang
