  • 16 Vote(s) - 3 Average
Gates tripped
Thank you for your enquiry.
Yes that is correct you should have constant voltage at both of the photocells as one will be the receiver and one be the transmitter if either of these are not powered, the system will not function.
Usually when the gates trip the RCD there is a short between live and earth, this could potentially be a motor issue. I have had the issue before where a motor is causing the same type of fault, I would recommend testing the motor individually in the board first and seeing if you can get the fault to reoccur with one of the motors.
Gates tripped - by Phil.c - 15-04-2024, 08:53 AM
RE: Gates tripped - by Phil.c - 18-04-2024, 08:06 PM
RE: Gates tripped - by benbrooks - 22-04-2024, 11:27 AM
RE: Gates tripped - by Phil.c - 01-05-2024, 09:34 AM
  Gates not staying open JimM169 1 2,790 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,479 21-08-2024, 12:21 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 10,276 04-05-2024, 12:41 PM
  Came ZA3 gates stuck open Ivorwindybottom 0 3,095 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 8,143 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 15,046 07-01-2024, 07:11 PM
Last Post: Simon NW
  Gates Opening After Closing tht7 2 15,702 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 30,510 23-02-2023, 01:08 PM
  Aria 400 - gates keep opening and closing objohnuk 1 8,193 13-04-2022, 11:32 AM
