  • 21 Vote(s) - 2.9 Average
CAME ZLJ24 Control Panel
(13-04-2024, 12:44 PM)SmtsFnd Wrote:
(11-04-2024, 08:07 AM)Michael Wrote: Hi,
Do you notice any damage on the board? check the front and back for any water ingress. Or if you would like to forward some images over to technical@easygates.co.uk of the front and back of the board, we can take a look for you.
Easygates Ltd
Hi Michael,
Thank you for the offer. I pulled the board out yesterday and found the culprit. A slug had decided to turn itself into a new track, shorting one of the smaller capacitors against an IC chip (to my eyes anyway). Maybe a couple of resistors higher up on the PCB too.
I removed our sadly deceased friend, cleaned the contacts, and refitted to PCB, but the state remained the same.
I'm going to buy a replacement board and an adhesive seal for the control panel box to prevent any more unwanted guests. I'll post an update here once this is done.
Do you know if a new PCB would require any special installation software, or will it be plug and play + manual programming of the gate timings via the built in controller?
Thanks!
thanks for the update.
This controller will not need any specialist programming tool.
CAME ZLJ24 Control Panel - by SmtsFnd - 09-04-2024, 01:49 PM
RE: CAME ZLJ24 Control Panel - by Michael - 11-04-2024, 08:07 AM
RE: CAME ZLJ24 Control Panel - by SmtsFnd - 13-04-2024, 12:44 PM
RE: CAME ZLJ24 Control Panel - by JoeF - 15-04-2024, 10:38 AM
RE: CAME ZLJ24 Control Panel - by SmtsFnd - 25-04-2024, 08:38 AM
RE: CAME ZLJ24 Control Panel - by JoeF - 08-05-2024, 08:57 AM
  Came ZA4 control panel Pat 2 5,668 09-05-2025, 12:30 PM
  ZLJ24 and AXO Motors gone awry colmgillard 1 5,139 22-04-2025, 08:19 PM
Last Post: Mibbo
  Trouble accessing ZLJ24 Control Panel Box chich 2 6,901 06-10-2024, 12:15 PM
Last Post: chich
  Came ZA3 Control panel wiring help and setting up help 7 56,536 24-09-2024, 03:29 PM
Last Post: merefield
  ZLJ24 Reversed Paulgates 1 5,285 15-04-2024, 12:05 PM
  Came ZLJ24 Lyneve 1 7,463 16-07-2021, 12:35 PM
  Help with intercom to Came ZLJ24 paulaj 0 7,486 15-06-2020, 06:27 PM
Last Post: paulaj
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,640 02-05-2018, 06:18 PM
  Came ZA3 Control panel - Green LED Flashing BarryD 0 15,910 18-07-2016, 11:19 AM
Last Post: BarryD
  Came za3 control board and mag-lock? Erjujo 3 34,825 10-12-2013, 10:16 AM
Last Post: Blakey111
