  • 21 Vote(s) - 2.9 Average
CAME ZLJ24 Control Panel
Hello all,
My CAME automatic gates aren't working at the moment and I was hoping for a bit of a steer towards the root cause. I have checked out the following:
- fob batteries all ok
- object sensors are clear and the fuse is fine (this blew a couple of years ago and has been fine since I replaced it)
- the gate motors are not seized, I have put them into manual mode and can open and shut them no problem
When I opened the control panel box to see if I could program of reset the gates I noticed some water in the bottom of the box, it has been raining a lot here for the last few weeks. The programming display is only showing solid bars, and the four buttons below did nothing to change this.
The PCB and transformers appear dry from the front and there is power to the board, however my instinct is leaning towards the PCB being damaged and needing replaced.
Any insight would be hugely appreciated.
Thanks!
CAME ZLJ24 Control Panel - by SmtsFnd - 09-04-2024, 01:49 PM
RE: CAME ZLJ24 Control Panel - by Michael - 11-04-2024, 08:07 AM
RE: CAME ZLJ24 Control Panel - by SmtsFnd - 13-04-2024, 12:44 PM
RE: CAME ZLJ24 Control Panel - by JoeF - 15-04-2024, 10:38 AM
RE: CAME ZLJ24 Control Panel - by SmtsFnd - 25-04-2024, 08:38 AM
RE: CAME ZLJ24 Control Panel - by JoeF - 08-05-2024, 08:57 AM
  Came ZA4 control panel Pat 2 5,668 09-05-2025, 12:30 PM
  ZLJ24 and AXO Motors gone awry colmgillard 1 5,139 22-04-2025, 08:19 PM
Last Post: Mibbo
  Trouble accessing ZLJ24 Control Panel Box chich 2 6,901 06-10-2024, 12:15 PM
Last Post: chich
  Came ZA3 Control panel wiring help and setting up help 7 56,536 24-09-2024, 03:29 PM
Last Post: merefield
  ZLJ24 Reversed Paulgates 1 5,284 15-04-2024, 12:05 PM
  Came ZLJ24 Lyneve 1 7,463 16-07-2021, 12:35 PM
  Help with intercom to Came ZLJ24 paulaj 0 7,486 15-06-2020, 06:27 PM
Last Post: paulaj
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,640 02-05-2018, 06:18 PM
  Came ZA3 Control panel - Green LED Flashing BarryD 0 15,909 18-07-2016, 11:19 AM
Last Post: BarryD
  Came za3 control board and mag-lock? Erjujo 3 34,825 10-12-2013, 10:16 AM
Last Post: Blakey111
