  • 14 Vote(s) - 2.93 Average
BFT Rigel 4 - single Gate Not Closing
(03-01-2024, 12:19 PM)Tsnash Wrote: Hi, I have a single gate that is using an old BFT Rigel4 control board which is currently permanently open. I’ve managed to narrow down (or at least overcome) the issue by disconnecting the external manual (push to make) switch, thus the gate now opens and closes via the remote fobs, albeit the sensors if interrupted use to trigger re-opening if an obstruction was detected, currently (with switch disconnected) the gate simply stops immediately. I’ve tested the manual switch and that appears to be fine although I haven’t checked the cable for a short.
Before I call out an engineer, does anyone have any further ideas to isolate the issue please?
Thanks in advance.
Think you are correct, sounds like a short circuit on the NO/COM connections for the impulse commands.
BFT Rigel 4 - single Gate Not Closing - by Tsnash - 03-01-2024, 12:19 PM
RE: BFT Rigel 4 - single Gate Not Closing - by JoeF - 04-01-2024, 10:21 AM
  BFT Gate Motor - Not working elyoussef.ali 1 6,082 11-09-2025, 10:15 AM
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 1,783 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,693 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 1,982 26-03-2025, 12:07 PM
Last Post: Talonfinger
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,784 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,217 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,440 04-11-2024, 05:59 PM
  BFT Rigel 5 - Phot message robs999 2 4,591 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 4,810 30-10-2024, 12:54 PM
Last Post: Vaf888
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 4,918 15-10-2024, 10:37 AM
