  • 14 Vote(s) - 2.57 Average
LIFE AC4 Closing Issues
Has anyone come across the following situation ?
I have an AC4R and the F2 fuse blew on the RG1R DL controller due to a slug crawling inside.
I have replaced the fuse and reset, but since then, despite resetting the gate several times, it always stops after a meter or so when closing. Then again a meter or so later etc when you press the button again on the remote (it continues to try to close rather than revert to opening).
Opening is usually fine.
As the gate and rail was old – I have replaced the rails and wheels.
I have also replaced the RG1R DL controller.
The same problem is still apparent and the gate always stops after a meter or so. Sometimes I get the 5 red lights flashing and sometimes there are 3.
I have also replaced the photo cells and they seem to operate correctly.
I have factory reset several times and it follows the correct process of resetting the gate travel (open & close), then is fine on opening but stops on closing.
Is there anything else on the AC4R that could have failed when the slug shorted the RG1R DL board.
I can’t find an in depth manual on the internet to help troubleshoot and am getting really frustrated I cannot fix the issue.
 there a setting I should change having reset the RG1R DL complet
Many thanks :-)
LIFE AC4 Closing Issues - by dilbertdog - 29-07-2023, 02:59 PM
  Beninca BOB30ME - Not closing all the way OMH 1 525 09-01-2026, 09:54 AM
  Gate not closing thronetm 0 4,337 16-11-2024, 09:25 PM
Last Post: thronetm
  Nice Gates not closing StuL 1 8,258 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,695 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Robus 600 not closing fully All Well 11 23,663 03-08-2022, 02:42 PM
  Aria 400 - gates keep opening and closing objohnuk 1 8,185 13-04-2022, 11:32 AM
  What is the life of a gate limiter magnet? Jaybee 0 6,444 13-11-2021, 09:38 AM
Last Post: Jaybee
  Faac 455d Gates not closing, 2 led bars on display only Mkeowd 0 6,625 26-09-2020, 02:29 PM
Last Post: Mkeowd
  Faac 770 455D Gates Auto closing framsbottom 6 25,352 23-04-2020, 08:56 AM
Last Post: framsbottom
  bft giuno ultra bt a20 not closing trackham 0 5,069 21-01-2020, 11:47 AM
Last Post: trackham
