  • 29 Vote(s) - 3.1 Average
Beninca bob motor wiring to board
(29-10-2022, 06:30 PM)Ranch2 Wrote: Hello, I am moving my system to accommodate new gates etc i have a Benica Brain 24 and Beninca bob Motors.  The motor has 5 connections one for positive and negative which is ok.  It has another three connections that go back to the board numbered
(3 Encoder signal)
(4 Encoder Positive)
(5 Encoder negative)
Where do these connect to on the board for motor one and motor two
the board is as follows
13 = COM
14 =SW01
15=SWC1
16=SW02
17=SWC2
18=PHOT
19=PHOTC
20=STOP
21=OPEN
22=CLOSE
23=PED
24=P.P
25=COM
Thanking you in advance
Think i got it after reading instruction manual a bit slower but one wire i am still not sure of is no 3
(3 Encoder signal) Not sure about this one does it go to com does anyone know?   Sad  if it does would the two motors go here
(4 Encoder Positive) This is the Input close limit switch (N.C. contact) does it go SWC1 on the board as that is the input close limit switch (normally closed contact) whatever that means
(5 Encoder negative) This is the Input close limit switch (N.C. contact) does it go SW01 on the board as that is the input open limit switch (normally closed contact) whatever that means
Thanking you all in advance
Beninca bob motor wiring to board - by Ranch2 - 29-10-2022, 06:30 PM
RE: Beninca bob motor wiring to board - by Ranch2 - 01-11-2022, 01:46 PM
RE: Beninca bob motor wiring to board - by Ranch2 - 03-11-2022, 06:41 PM
RE: Beninca bob motor wiring to board - by SamA - 04-11-2022, 09:28 AM
RE: Beninca bob motor wiring to board - by Ranch2 - 15-11-2022, 07:31 PM
RE: Beninca bob motor wiring to board - by SamA - 18-11-2022, 09:59 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,892 09-01-2026, 10:03 AM
  Beninca BOB30ME - Not closing all the way OMH 1 532 09-01-2026, 09:54 AM
  Beninca actuator arm not moving at al Andruelectricgates 1 317 09-01-2026, 09:49 AM
  Circuit board disabled CB124 - 7 flashes Tussun 6 21,746 15-08-2025, 01:57 PM
  Beninca TOM4024E wiring Shropshire_Lad 1 2,260 14-07-2025, 01:59 PM
  FAAc xp20d wiring Neil Young 4 6,157 04-02-2025, 12:08 PM
Last Post: Neil Young
  Fried control board nickfr 3 5,652 22-03-2024, 12:53 PM
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 3,813 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 6,834 09-02-2024, 06:13 PM
  TC fault code on Q60ar control board Skydive1710 3 10,137 20-11-2023, 03:12 PM
Last Post: NormanY
