  • 36 Vote(s) - 2.67 Average
(06-10-2022, 10:29 AM)SamA Wrote:
(30-09-2022, 07:46 PM)Noghar Wrote: " The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
Hope this helps.
Thanks for your help. Smile
Nice transmitters - compatibility - by Noghar - 29-09-2022, 05:05 PM
RE: Nice transmitters - compatibility - by SamA - 30-09-2022, 03:04 PM
RE: Nice transmitters - compatibility - by Noghar - 30-09-2022, 07:44 PM
RE: Nice transmitters - compatibility - by Noghar - 30-09-2022, 07:46 PM
RE: Nice transmitters - compatibility - by SamA - 06-10-2022, 10:29 AM
RE: Nice transmitters - compatibility - by Noghar - 07-10-2022, 02:20 PM
  Nice LFAB occasionally failing open DaveHG 3 10,094 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,364 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,047 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,721 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,828 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 5,442 16-02-2025, 05:16 PM
Last Post: gatekeeper
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,925 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 8,372 10-12-2024, 10:31 AM
Last Post: dmrgate
