  • 19 Vote(s) - 3.42 Average
Proteco controller & ACT5e keypad - keeps tripping
Thanks for this
The system works perfectly without the keypad connected.
I have connected the keypad to an old physics lab power supply where I can read off the current draw - it seems in order at around 50 to 80ma.
I am going to circumvent the installed cable and run a quick test cable keypad directly to the box to see if as you suggest, there is some issue in the installed cable. I've always had a suspicion this cable was compromised on installation but its failure is intermittent (perhaps weather or moisture dependant etc)
RE: Proteco controller & ACT5e keypad - keeps tripping - by fclauson - 20-08-2022, 06:23 AM
  Digipro keypad 0161Geezer 0 2,182 22-03-2025, 07:16 PM
Last Post: 0161Geezer
  Trying to identify this Gate Controller - HOCHE UC109? RossAM 0 4,352 02-08-2024, 04:47 PM
Last Post: RossAM
  Identify controller/PCB? Jack.toland 4 6,035 18-01-2024, 11:58 AM
Last Post: Jack.toland
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,683 26-09-2023, 05:32 AM
Last Post: max666
  Rigel 5 - second keypad stopped working HarefieldHse 1 4,992 03-07-2023, 08:48 AM
Exclamation Proteco Q60A stopped working xCO 0 3,488 19-06-2023, 01:03 PM
Last Post: xCO
  Controller CL20S replacement Kaala1 6 13,725 15-03-2023, 09:23 AM
  Ditec VIVAH controller Bollidear 1 4,739 07-11-2022, 11:12 AM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,694 12-07-2022, 11:48 AM
  Proteco Q60 - FH error then close after opening Needlerp 1 6,042 24-06-2022, 09:54 AM
