  • 21 Vote(s) - 2.86 Average
Hello - Another Proteco Q60A/R Question!
Hi there,
In a desperate attempt to avoid forking out £150 for a replacement board, which might not even fix the problem, I'm wondering if anyone can possibly help!
After years of service, and a few niggles, I'm getting the 'N1' motor 1 error. I've already tried the following:
1) Checked the circuit board for any visible signs of corrosion, damp, short circuits, or fried components - None
2) Checked all the wiring into, and out of, the control unit, and to the motors - Looks fine
3) Checked and tightened up all the wiring into the terminal blocks - Checks out
4) Checked the torque settings on the motors - Both maxed
5) Switched it to single motor operation, and tested the motors individually (i.e. just 13/14/15, and then plugging 16/17/18 in the 13/14/15) - It carries on saying 'N1' in both cases.
I can hear the switch/solenoid/motor coming on for a fraction of a second, but then it immediately stops.
Given swapping the motors over made no difference, it seems unlikely to me that both motors have failed at the same time. And, by the same logic, the capacitors are unlikely to be the problem. My current theory is that there is a problem with the board itself, and if so, I'll need to replace it.
Any suggestions would be fantastic!
Many thanks - I know it's old kit, but it still sad when it's beyond repair.
SawboMan
Hello - Another Proteco Q60A/R Question! - by SawboMan - 03-07-2022, 06:35 PM
  q60a stevea 1 2,687 23-08-2024, 12:14 PM
Last Post: stevea
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,735 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,512 19-06-2023, 01:03 PM
Last Post: xCO
  Replacement Q60A board? ndyhzlwd 1 5,829 10-02-2023, 03:19 PM
  First Post.. With question Yos Sam 5 10,903 04-11-2022, 09:27 AM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,511 26-08-2022, 03:42 PM
  proteco q60a microcontroller program arashkhan 1 5,780 17-06-2022, 01:29 PM
  Proteco Q60 AR ...Fob wont program Shane1 0 3,966 12-01-2022, 08:13 PM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,344 22-10-2021, 09:57 AM
Last Post: Luc Bevers
