  • 32 Vote(s) - 2.97 Average
Proteco Aster 3 ram fault
So three months later the other ram motor of the pair failed with a pop. When I took this one apart and found an almost identical burn-out in almost the same place on the winding, close to the sleeves which cover the joints between the wires from the power cable and the windings, I think the problem is that the enameled wire of the common connection and the forward or reverse windings cross almost at right angles so there is full mains voltage separated by two layers of enamel insulation which has broken down for some reason. Seems like a design flaw.
These rams are about 8 years old, Have other folks found that this make of ram fail after this sort of time ?
Proteco Aster 3 ram fault - by soother - 19-04-2021, 10:30 PM
RE: Proteco Aster 3 ram fault - by soother - 23-04-2021, 09:09 PM
RE: Proteco Aster 3 ram fault - by soother - 14-07-2021, 11:58 PM
  TC fault code on Q60ar control board Skydive1710 3 10,134 20-11-2023, 03:12 PM
Last Post: NormanY
  FAAC E124 fault 05 allan@amtas.com.au 0 3,627 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,735 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,512 19-06-2023, 01:03 PM
Last Post: xCO
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,798 03-02-2023, 12:00 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,511 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,735 12-07-2022, 11:48 AM
  Q80A Strange fault. Cannot work it out, if setting or fault? gray 0 3,518 25-06-2022, 08:14 AM
Last Post: gray
