- 32 Vote(s) - 2.97 Average
- 1
- 2
- 3
- 4
- 5
Proteco Aster 3 ram fault
Threads: 1
0
23-04-2021, 09:09 PM
(This post was last modified: 24-04-2021, 01:38 PM by soother.)
No replies! Before ordering a new ram I decided to get stuck in and find out why one motor winding was open circuit. I used an angle grinder to make two openings in the bottom end of the motor housing, then drove out the stator assembly by alternate whacks with a hammer and nail punch. Once apart, a burn spot was visible on the bottom end where the winding had burnt out. After some dissection, I could see that the arc had vaporised wires leaving 6 loose ends, so it was not surprising that the winding was reading as not connected. After some precision soldering under magnification and trying different permutations of the 6 to give equal resistance (about 75 ohms) for each winding, it is now re-connected, the motor is reassembled, and the ram is working properly and back on the gates.
I took the attached photos of some steps of the process.
| Messages In This Thread |
RE: Proteco Aster 3 ram fault - by soother - 23-04-2021, 09:09 PM
| Possibly Related Threads… |
| Thread |
Author |
Replies |
Views |
Last Post |
TC fault code on Q60ar control board |
Skydive1710 |
3 |
10,139 |
20-11-2023, 03:12 PM
Last Post: NormanY
FAAC E124 fault 05 |
allan@amtas.com.au |
0 |
3,628 |
14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
Proteco Advantage (Q60A) Error Code "03" |
CLAUDIOTX |
3 |
23,739 |
26-09-2023, 05:32 AM
Last Post: max666
Proteco Q60A stopped working |
xCO |
0 |
3,516 |
19-06-2023, 01:03 PM
Last Post: xCO
Q80A Fault Code |
kevcl15@yahoo.co.uk |
1 |
5,805 |
03-02-2023, 12:00 PM
Proteco controller & ACT5e keypad - keeps tripping |
fclauson |
4 |
10,517 |
26-08-2022, 03:42 PM
Hello - Another Proteco Q60A/R Question! |
SawboMan |
2 |
7,738 |
12-07-2022, 11:48 AM
Q80A Strange fault. Cannot work it out, if setting or fault? |
gray |
0 |
3,520 |
25-06-2022, 08:14 AM
Last Post: gray
Proteco Q60 - FH error then close after opening |
Needlerp |
1 |
6,078 |
24-06-2022, 09:54 AM
proteco q60a microcontroller program |
arashkhan |
1 |
5,782 |
17-06-2022, 01:29 PM
