  • 30 Vote(s) - 3.03 Average
MHouse WS2S
Can you please advise on the problem I have with my gates (MHouseKit WS2S) following a mains  power failure. Gate mechanism some 10 years old, never any problems before
1. None of the remote controls will operate the unit, batts OK in all
Note - The manoeuvre does not start and the flashing light is off, book says -  check command is received, I hear a relay click but LED on OPEN (D) does not light up - LED on ECsbus gives one long flash then returns to flashing every second
2. There are no problems with power to the control unit
3. LED ECSbus (A) is flashing once per second - book says this means all is OK
4. LED STOP (B) is on - book says this means all is OK
5. LED OPEN © is off - book says all is OK
6. LED P1 (D) is Off - everything OK
7. LED P2 (E) is Off - everything OK - see later *******
8. LED P3 (F) is On - everything OK
Note - when first examined after restoration of power LED P2 (E) was flashing once per second - book says The learning phase has not been carried or there are errors in the memory data, book says some faulty devices may be present and redo "learning other devices".
Redid learning other devices and after the operation the LED P2 remained off.
Photocell problem, memory corrupt, circuit board failure????????
Any help appreciated
MHouse WS2S - by Bricodust - 24-03-2021, 09:25 PM
RE: MHouse WS2S - by SamA - 29-03-2021, 01:11 PM
RE: MHouse WS2S - by Bricodust - 30-03-2021, 01:26 PM
  Mhouse sl10 not closing Mark Reader 1 6,088 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 6,106 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 7,976 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 10,225 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,531 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 31,119 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 14,091 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 8,378 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 16,817 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 8,576 13-04-2022, 11:18 AM
