  • 289 Vote(s) - 2.62 Average
Radio control
David Brisland Wrote:I have fitted sub300 gate closers and a cb11 controll box one set of photo cells everthing is working and set up but they wont with remote control
Hi, Have you set up the photocells? you do this by turning the power off, placing a jumper over the terminals labelled "Save Fail Safe Photocells", then turning the power back on and removing the jumper after 15 seconds.
Also check your radio board is plugged into the CB11.
Hope this helps,
Radio control - by Colin - 28-02-2009, 08:50 PM
RE: Radio control - by easygates - 02-03-2009, 05:01 PM
RE: Radio control - by David Brisland - 19-03-2009, 08:53 PM
RE: Radio control - by easygates - 22-04-2009, 04:01 PM
  New enclosure for existing control panel BenH 0 2,153 05-06-2024, 12:49 AM
Last Post: BenH
  Computer controlled control panel dsbhachu1 0 2,410 18-02-2024, 11:35 AM
Last Post: dsbhachu1
Last Post: NormanY
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,923 25-05-2023, 03:55 PM
Last Post: Kaala1
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,189 02-12-2022, 02:51 PM
  CAM ZA3 Single control board Rookie 1 11,126 13-04-2022, 11:37 AM
  q60 ar control panel markythesparky 0 3,714 13-11-2021, 06:21 PM
Last Post: markythesparky
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 4,194 04-10-2021, 02:34 PM
Last Post: wildfig
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,606 02-05-2021, 09:00 PM
Last Post: soother
