  • 492 Vote(s) - 2.99 Average
I have a Chamberlain Liftmaster 300k actuator operating a single leaf gate. The control unit is a Liftmaster CB1 unit. All was working well when the unit stopped working. Inspection revealed that the motor start capacitor had burned out. I purchased a replacement unit of the same type and capacity and installed it. When I operated the gate it was slow to start. When it did start the settings were all wrong with the gate stopping halfway through the travel. I've tried resetting the gate position and retrying but the operation is no longer consistent in operation and sometimes fails to operate.
I've not tampered with the board settings as the setting were fine before the capacitor failed.
I'd be grateful for any advice from anyone who has experienced a similar problem. Alternatively does anyone know of a suitable maintenance company in the Stratford on Avon area in the UK Midlands.
Armstrong Wrote:I have a Chamberlain Liftmaster 300k actuator operating a single leaf gate. The control unit is a Liftmaster CB1 unit. All was working well when the unit stopped working. Inspection revealed that the motor start capacitor had burned out. I purchased a replacement unit of the same type and capacity and installed it. When I operated the gate it was slow to start. When it did start the settings were all wrong with the gate stopping halfway through the travel. I've tried resetting the gate position and retrying but the operation is no longer consistent in operation and sometimes fails to operate.
Hi, try turning up the runtime and the force of that motor. if the capacitor is the same type then it should be working o.k. maybe the arm is damaged.
i will attach the CB1 instructions for your reference.
you could try swapping the motors over on the board. this will tell you if the board is the fault or the motor.
.pdf   cb1.pdf (Size: 357.6 KB / Downloads: 2,045)
Swapping the motors worked just fine for me!
Thanks for the tips.
______________________________________
Alexandra from GCS
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 1,711 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 28,149 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Sun affecting gate opener ForestRon 2 12,458 02-09-2024, 03:54 PM
Last Post: ForestRon
  Liftmaster LA400 Defender 6 23,522 03-08-2023, 12:26 PM
Last Post: Torantrieb
  Problem with delay time CB11 milan 2 15,420 04-10-2021, 01:44 AM
Last Post: DesmondVog
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 24,201 22-02-2021, 08:48 PM
Last Post: russ
  Loose gate stop but what wrench to use? bomitie 2 14,269 02-04-2020, 12:06 PM
  Liftmaster CB1 gates started to open themselves telnet123 4 36,371 01-01-2020, 09:43 AM
Last Post: pronosoft
