  • 143 Vote(s) - 2.88 Average
Re: Error 30
Wondered if you could help?  I have an automatic gate (DEIMOS BT 500kg) which is having problems opening/closing.  It's coming up with Error 30 on the electronic display.  Any ideas what the problem could be as I can't find this fault code in the instruction manual.
Thanks.
can you unlock gate to manual opening, just for checking how easy it can be close by hand ?
Best Regards
Tom
The gate will open and close fully in the test mode but when using the remote control, the gate will not always open fully and Error 30 is displayed. You have to go through the test routine to get the gate to close properly again.
Regards, Tony
  Thalia P - BAR error devsolo 3 18,350 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,264 17-01-2025, 10:06 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,738 26-09-2023, 05:32 AM
Last Post: max666
  Deimos BT 400/600 error codes orange 0 6,087 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,323 02-09-2020, 07:06 PM
Last Post: Adam67
  BFT Error 35 & 37 Not opening fully - SOLVED razer raz 4 52,027 14-11-2017, 04:02 PM
Last Post: razer raz
  Q60A/R error. Showing "_ " Jonas Pistolas 4 24,546 03-11-2017, 10:19 AM
Last Post: Jonas Pistolas
Question Proteco q80s Error 44 Cphats 1 12,587 13-08-2017, 11:15 PM
Last Post: gerardo
  BFT Deimos BT Error Codes rajesh 1 21,581 05-06-2017, 11:07 AM
