  • 167 Vote(s) - 3.41 Average
Bft gate tripping
Hello. Got some bft gates. Everything works fine. Then every other day the main 5amp switch form the mains will trip.
It doesn’t happen when I’m opening the gates. So it’s not the motors. It only happens when the dogs are in a certain area. I’m guessing it’s either the photocells. Or the aerial. Can the bft aerial make a fuse trip if a dog were to climb on it. They have already ripped the aerial stub off it. I’m thinking water might have got it.
Has it got power going to it ?
The dogs can walk through the photocells hundreds of times a day and not go off. Only when they go in one particular corner. That’s were the aerial is and a photocell. Many thanks for your help
(02-01-2018, 03:00 PM)Mjc Wrote: Hello. Got some bft gates. Everything works fine. Then every other day the main 5amp switch form the mains will trip.
it's not aerial
it something else ,check photocells .
Best Regards
Tom
it's not aerial
THANKS. So if the photocells are faulty. As soon as I switch the 3am fused switch to make the rigel5 Panel live. that will make The fuse pop? We’ve had a lot of rain recently. Could be water ingress in the photocells.
it's not aerial
if you have water everywhere do not touch gate stay away from it !!!! switch off the power .
Best Regards
Tom
it's not aerial
o
The power is off. The control box is dry. The motors are dry the 5amp fused switch is dry. The only thing I havnt checked is the photocells. What I wanted to know was- can water ingress in photocells. Cause the fused to blow as soon as I turn on the power with a new. Fuse. Thanks for your help. Greatly appreaciated.
it's not aerial
o
it's not aerial
o
Of course, the water can get into the photocell.
check the lamp as well
regards
Best Regards
Tom
(02-01-2018, 09:01 PM)Automatic-TC Wrote: hi
it's not aerial
o
regards
Thanks for your help. I have no lamps on the gates. The only other thing I havnt checked is the key over ride box to open the gates. I will look at the key over ride and the photocells. Gotta be them. Every other part is dry and intact.
it's not aerial
o
regards
  Help me identify this mystery gate opener alpha 5 4,636 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 1,716 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 4,760 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,402 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,309 18-03-2025, 06:40 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 29 57,116 27-02-2025, 03:08 PM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 12,587 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,058 16-11-2024, 09:25 PM
Last Post: thronetm
  Gate kit recommendation electric gate harry 0 3,880 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 4,503 28-08-2024, 05:13 AM
Last Post: drewdavis
