  • 159 Vote(s) - 3.04 Average
MC424 - close automatically once open
i have installed Nice MC424 at home, (opening in direction inside), at works perfect.
I have bought the same set to my father, and configured in the same way, but does not work properly. Only difference is that at fathers home gates are configured to be opening in direction outside. But connection of wires should be the same per seller.
Gate itself works well when i stop it while opening using remote. When i hit button, it starts opening, when i hit button again while gate is moving, gate stops. When hit button again, gate will close and will remain closed.
But the problem is when i want to just open it.
In my place, the i hit the button, gate will open, will wait 20 seconds and than will close automatically.
In father house it does not work.
When i hit remote control, gate will open, but just when it will finish opening, gate will start closing automatically, without waiting 20 second.
I have put gate into factory settings, but did not solve the problem.
Any idea what might be wrong?
Marek
(02-12-2017, 04:11 PM)maaarek Wrote: Hi,
Marek
if that issue will hapen again ,check diagnostic led P2 follow manual .
slow down engines speed , thats my suggestion
Best Regards
Tom
Marek
Hi Automatic-TC,
it is always with this incorrect behavior. I will check it tomorrow with lower speed and diagnostics.
When exactly i should see diagnostic led blinking? Once system is restarted? Or how to enter diagnostic menu? Or do i undestand it correctly that i should be watching this diagnostic led (P2) during opening of Gate?
One additional question. I understand others, but any idea what does it mean in manual in diagnostic section "M1/2 current sensitivity device triggering"?
Marek
Marek
Hi Automatic-TC,
Marek
watch control board all time than hit the button .. i think that could by amperometric issue with engine . slowing down engine speed should help
regards
Tom
Best Regards
Tom
  Nice LFAB occasionally failing open DaveHG 3 10,094 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 8,364 15-08-2025, 02:01 PM
  NICE gates open slightly then stuck Overthefence 2 4,721 21-05-2025, 10:54 AM
  Mag-lock not activating after close benkay 4 9,543 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,925 10-12-2024, 11:29 AM
  MC424 PhotoCell Bypass for Constant Power AdamG 0 2,653 29-06-2024, 02:45 PM
Last Post: AdamG
  Nice MCA1 stuck open after stop command Khooke 1 6,576 25-09-2023, 10:47 AM
  Nice Robus Don't Auto Close!!!! Ali_1982 1 7,722 03-08-2022, 02:23 PM
  Auto close and hold open kensuth 1 7,713 14-03-2022, 11:49 AM
  MC424 install WI-FI Switch dreqonline 6 19,678 07-03-2022, 11:05 AM
