  • 192 Vote(s) - 2.91 Average
BFT Error 35 & 37 Not opening fully - SOLVED
HAve a DEIMOS ULTRA BT A600. Gate wont open fully.
Error 35 & 37 popping up - cant find out what it is.
Also a photocell has been hit recently ( can here relay working and gate working as expected when the cell is covered)
Any advice welcome!
(12-11-2017, 05:37 PM)razer raz Wrote: Hi,
Any advice welcome!
are you sure that was error 35/37 or Er 3H ?
did you try to open the gates manualy ?
Best Regards
Tom
Please see below the error codes.
Error code 35 - Opening obstacle motor 1
Error code 37 - Slowdown opening obstacle detection motor 1
I would check that there is nothing which could be causing an obstacle and check that the gate moves freely without any resistance spots, hope this helps.
(14-11-2017, 10:32 AM)TimK Wrote: Hi,
Thanks for the codes Smile
Ill have a look to see if anything is causing resistance ( this does corroborate with the display showing a higher load on the motor than the other leafs motor - which isn't presenting any error codes either)
All sorted gents.
Found debris underneath the guide rail, stopping the guide wheels passing by.
Once removed, gate runs smoothly!
Cheers!
  came bx-b clicking & not opening misssmith 1 3,316 13-03-2025, 09:57 AM
  Thalia P - BAR error devsolo 3 18,348 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,262 17-01-2025, 10:06 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,737 26-09-2023, 05:32 AM
Last Post: max666
  Gates Opening After Closing tht7 2 15,699 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Robus 600 not closing fully All Well 11 23,677 03-08-2022, 02:42 PM
  Aria 400 - gates keep opening and closing objohnuk 1 8,191 13-04-2022, 11:32 AM
  Deimos BT 400/600 error codes orange 0 6,087 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,322 02-09-2020, 07:06 PM
Last Post: Adam67
