  • 267 Vote(s) - 3.13 Average
MHouse WG20 problem
One of the gates was not closing fully, so I tried to re-set - I undid the locking mechanism's which was difficult as they were hard to move. I moved the gates to half way point as it says in the manual 3.5.2 but now nothing happens - P3 light is just flasing constantly. I have turned off electric and tried again but P3 just keeps flashing which it says is because opening mechanism not recognised.
I have tried to do the intial set-up 3.5.1 again but still P3 just keep flashing and there is no response from gates at all - on P3 button or remotes
I had to pull hard to get the gates to move, even after turning the unlock on the arms - could I have pulled gates off the cogs or something?
Advise please as to what I should try???
Firstly we need to check a few parts of the installation.
1. What size motor cable are you using?
2. What is the current status of the stop LED?
3. Is the Bluebus light flashing more than once per second? if yes how many times a second?
  Mhouse sl10 not closing Mark Reader 1 6,090 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 6,108 03-02-2025, 09:56 AM
  Problem with WS2 + CL2 petec_uk 2 4,402 02-08-2024, 02:37 PM
Last Post: petec_uk
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 7,977 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 10,225 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,533 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 31,126 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 14,098 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 8,379 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 16,822 30-05-2022, 09:15 AM
