  • 226 Vote(s) - 2.94 Average
BFT Rigel LUX FC actuators erratic
Have just newly installed the above system to open two wooden driveway gates but they are behaving strangely and need I some advise before I go crazy please! I have not installed or programmed any of the safety feature yet as cannot get the basic system working.
The system will operate for maybe 5-6 cycles with the gate 1 opening first and then after short delay gate 2 opens, motors run, gates reach stops and motors stop running then after the programmed time (20seconds) the gates close with gate 2 closing first. Then it starts to go wrong and gate 1 runs through the cycle correctly but gate 2 stays in open position all the time. If you feel the gate 2 actuator motors it is humming but not actually starting the motor.
The only way i can get it to restart is to keep using the remote to start & stop the cycles half way through and eventually gate 2 will close, but then we are back to square one and it will operate a few times then stay open.
I have run through the logic / programme several times and nothing seems an issue as I have tried to keep default programme as much as possible. HELP!!
  Rigel 5 , gates won't open Nameloc 4 10,273 04-05-2024, 12:41 PM
  BFT Rigel 6 stevew 3 6,663 29-08-2023, 08:39 AM
  Rigel 5 - second keypad stopped working HarefieldHse 1 5,027 03-07-2023, 08:48 AM
  Strange gate operation Rigel controller Philreghse 0 8,411 10-06-2019, 09:18 AM
Last Post: Philreghse
  Rigel 4 and Clonix not receiving signals apbran 6 32,083 26-03-2017, 05:32 PM
Last Post: apbran
  BFT Rigel 5 graham 2 17,305 20-05-2013, 01:55 PM
Last Post: graham
  BFT Rigel 5 Remote sync Nicks 1 15,023 01-03-2013, 02:15 PM
