  • 234 Vote(s) - 2.79 Average
Proteco Q36a problems
I have a Proteco Q36a swinging gate controller and I am having some problems.
It seems that the two engines didn´t get any current and so the gates dont open.
I didn´t change any wire and until now it was working fine.
The display on the board shows "--" which is the standby. When I press the remote controller
I can see "-.-" on the display which shows that the board is receiving the signal but then nothing happens.
I have already tested to shorten the 1 & 8 pin and then I can see "Go" on the display and I can hear a tick but the gates didn´t open. After some seconds the display shows "--" again.
While that I have meassured the voltage of the engine1 and engine2 and there is always 0V.
The main power is working fine and has 230V.
I also checked the both fuses which are on the board and both are fine.
Is there anything else that I can test to see if the board is broken?
It would very nice if you can help me.
Thank you in advance for your help.
Best Regards
Daniel
Last Post: max666
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,517 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,738 12-07-2022, 11:48 AM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,349 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,202 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,693 14-07-2021, 11:58 PM
Last Post: soother
