  • 180 Vote(s) - 2.87 Average
Just Got A Rigel 5 and need HELP!!!!
Hi i'm having problems wiring my new Rigel 5, i use to have the Altair -P but it broke down, i also have the BFT Igea motors which worked well will my old system, but now with the Rigel 5 i cant seem to get the wiring right. I have put the earth into from motor 1 into 5 and blue into 4 and brown into 6, and the same for motor 2 but they open but not close, if i change them over they close but do not open. Has anyone any ideas please.SmileSmile
(07-10-2012, 06:14 PM)rapley Wrote: Hi i'm having problems wiring my new Rigel 5, i use to have the Altair -P but it broke down, i also have the BFT Igea motors which worked well will my old system, but now with the Rigel 5 i cant seem to get the wiring right. I have put the earth into from motor 1 into 5 and blue into 4 and brown into 6, and the same for motor 2 but they open but not close, if i change them over they close but do not open. Has anyone any ideas please.SmileSmile
Did you ever resolve this problem? I have a similar problem - 2 new BFT motors (and capacitors) installed onto an existing Rigel 5 control board, one side is fine, the other only moves in one direction on both open & close cycles. That direction is reversed if cables reversed.
Hello! Have you managed to solve the problem? I seem to have the same issue that it can both close but Motor 2 terminals does not open. A new capacitor does not help. Switching the hydraulic arms simply switch the sides (ie the hydraulic arms are working).
Many thanks.
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,695 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Rigel 5 Talonfinger 0 1,982 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,217 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 4,595 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 4,815 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,643 17-05-2024, 10:28 AM
Last Post: Adamit
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,096 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,673 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 6,849 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 12,321 10-10-2022, 01:10 PM
