  • 237 Vote(s) - 2.89 Average
Help with Proteco Slower4 connections
Hello to all forum members; I landed in this forum after trying to find some instructions to install an old swing gate arm.
I live in Chile (Southamerica) and will appreciate any kind of help from you guys.
I´m a D.I.Y proyects fan, and now I want to install this automatic system in my house swing gate.
The componets I have are:
- 1 Proteco Slower 4 electric arm
- 1 S.A.T control board
- 1 electric lock
- 2 remote controls
I can´t find any inormation about this S.A.T control board, If any of you can provide me info about the electric conections in the control board I will be very thankfull.
I attached some pictures.
In my search I find that this Arm was also sold as an ASTER 4 in UK. The installation manual is available, but using the Q60 control board.
Anyone can help me with the connections in my S.A.T control board?
I notice that the transformer is missing in this control board. Can anyone help me to intall a new one. I can send a picture of the reverse of the control board to see the circuit.
Thanks, any help will be appreciate.
If you can afford it, just buy a new control board for swing gate operators. Your operator is a typical 230VAC operator and compatible with any board for 230VAC swing gate operators you can find. You will also need remotes, a capacitor for the operator (8 μF ?) and safety photocells.
Good luck.
PS: It is very possible that the board will not function correctly, even if you reinstall the transformer. And this is not counting that as you said you have no installation manual. I couldn't locate any info on S.A.T. and nobody I asked knew it either. You will probably have a hard time trying to find a manual for a 10-15 years old obscure piece of electronics.
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,738 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,515 19-06-2023, 01:03 PM
Last Post: xCO
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,516 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,738 12-07-2022, 11:48 AM
Last Post: Shane1
  Proteco Leader N1 problem Luc Bevers 0 4,348 22-10-2021, 09:57 AM
Last Post: Luc Bevers
  Proteco gates with photocell problem. Shane1 0 4,201 09-10-2021, 07:56 PM
Last Post: Shane1
  Proteco Aster 3 ram fault soother 2 8,692 14-07-2021, 11:58 PM
Last Post: soother
