  • 462 Vote(s) - 2.82 Average
Rigel 5... cell question
Hello all
Newbie here, trying to sort out my gates after the electrican messed them up!
Got the motors, capacitors and keyfobs sorted out.
I have a 'push to open button'. That is N/O across 30 and 31
My question is the photocells. Power is 20/21 for Rx and 20/44 for Tx (although I am sure they don't need separate supply connections)
I have a pair to trigger opening as you enter and another pair to trigger opening as you leave. Where do these connect?
I notice in the programming menu that they default stop and re-open if you break the beam while they are closing, which is what I need.
I also have a set directly across the gate line to prevent closure onto a car between the gates. Would these be wired N/C across 35 and 36?
If yes, then will they stop and reverse the gates or just hold them ?
Many thanks !
Steve
REF CELLS for free exit - WIRE TRIGGER RELAYS ( test em in the powered state ) to 30 & 31 volt free, this will always open the gates.
Safety cells on relay is 35&36
easier to power 20&21 for all cells
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 102,426 21-07-2025, 06:54 AM
Last Post: jojo351
  Question BFT Deimos A400 Makaroni 2 4,926 07-05-2025, 05:58 AM
Last Post: OnionBobo
  BFT Rigel 5 Talonfinger 0 2,193 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,572 03-02-2025, 11:29 AM
  BFT Rigel 5 - Phot message robs999 2 5,059 01-11-2024, 11:22 AM
Last Post: robs999
  Stressing over BFT Rigel 6 Help please Vaf888 3 5,362 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 2,889 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 18,208 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,462 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,934 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
