  • 301 Vote(s) - 2.87 Average
BFT LUX arm not fully closing
I am hoping that someone can help me with a problem I am having. I have a pair of LUX 2B FC arms controlled by a Rigel 5 panel. One gate opens and closes fine while the other one opens OK but when it closes, it stops before fully closing and leaves about a 6" gap.
I have increased the motor operation time on the control panel and can hear the motor running for about 3 seconds after the gate stops moving so I am reasonably sure that it is not a motor run time issue. I have also increased the torque cut out on the arm itself and that also made no difference.
Its worth noting that there is no closing ground stop fitted and I believe the FC arms have an internal stop mechanism in them instead and so I am guessing it is this that needs adjusting so my question is does anyone know how to adjust the closed rest position on these arms please?
Many thanks in advance
Pete
I do not recall that LUX has any limit switches. If you are saying that time is okay, torque is okay and valve on the operator is oaky (adjusted) and you can hear that motor is working for 3 seconds but not moving I would say that either there is no enough oil in the operator or you have to adjust ball joint at the gate bracket (by unscrewing it).
Can you fully close the gate in manual mode (by hand)? Have you got opening and or closing delay?
Okay LUX FC has got something what they call internal stop mechanism but this is only spring inside the operator (kind of dampener) and it is non adjustable.
I have attached supplement for LUX FC
.pdf   LUX FC.pdf (Size: 164.67 KB / Downloads: 2,211)
www.webseb.co.uk
Hi Thanks for your help with this. D
isconnecting the arm and adjusting the ball joint did the trick.
Thanks again
Pete
  BFT Sliding Gate randomly opening and closing AdrianMate 5 12,052 14-06-2024, 12:12 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 7,297 09-02-2024, 03:12 PM
Last Post: EdwardBab
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 5,463 04-01-2024, 10:21 AM
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 8,089 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 8,818 09-01-2023, 10:29 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 7,649 10-10-2022, 10:07 AM
  LUX G BT 2B not closing properly since manual override swinnie 1 5,204 03-08-2022, 01:44 PM
  Slider closing then reopens 8" MWJONES 4 26,291 14-03-2022, 12:04 PM
  BFT Lux 2B FC Motor not closing all the way jc.34@outlook.com 1 6,152 07-03-2022, 11:24 AM
