  • 303 Vote(s) - 2.9 Average
I've posted this in BFT as well but there is also a general question.
Thanks in advance
.pdf   SUb.pdf (Size: 57.98 KB / Downloads: 1,471)
Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
The legnth of the leaf is very important. For the size of each leaf being 2.5m you would require the SUB ER motors. The boxes you have already installed would be compatible. The SUB ER motors will be quite alot slower than the SUB R motors. They are also non-locking so security will be an issue as you can force the gates open.
With these non-locking motors, the seals will not break and should last a long time with regular service.
We can get these motors ordered in for you if you require them
If you need any more details please call us on 0845 054 50 70 and ask for Technical.
(13-04-2010, 06:44 PM)jgpp Wrote: Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 780 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,885 09-01-2026, 10:03 AM
  Help me identify this mystery gate opener alpha 5 5,797 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,511 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,509 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 5,100 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,669 18-03-2025, 06:40 AM
  Gate kit recommendation electric gate harry 0 4,180 10-09-2024, 03:57 PM
