  • 294 Vote(s) - 2.78 Average
aster 5 gate adjustment
my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Guest Wrote:my proteco aster 5 right hand opener functions but opens too far I assume adjustment is done by undoing from the gate and screwing the ram down a turn but I have discovered that the mechanism can be pulled out from the ram revealingthe internal mechanism have I damaged the opener and can I reinstall the mechanism toprevent it coming loose ?
Hi, you should have physical gate stops in the ground to stop the motor running to the end of its reach. also there should be a function on the board to decrease the motor run time, or there maybe a function to learn where the gates open and close to. you should refer to the manual for this information.
Hope this helps
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 780 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 61,884 09-01-2026, 10:03 AM
  Help me identify this mystery gate opener alpha 5 5,796 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,511 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,509 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 5,100 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,669 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 14,208 02-12-2024, 10:40 AM
Last Post: bing
Last Post: thronetm
  Gate kit recommendation electric gate harry 0 4,180 10-09-2024, 03:57 PM
