  • 9 Vote(s) - 2.78 Average
Beninca actuator arm not moving at al
i have a customer with a Beninca primier Actuator arm control by a brainy 24 i am getting a pno2 and the gate do not move i have tried all tricks in the book you can hear the clicker give the open command but gate do not move i have test
the arms indivaully with 24volts thay move freely how do i get rid of pno2 and get the gates in operation
Thanks Any help will do
(15-12-2025, 09:45 PM)Andruelectricgates Wrote: i have a customer with a Beninca primier Actuator arm control by a brainy 24 i am getting a pno2 and the gate do not move i have tried all tricks in the book you can hear the clicker give the open command but gate do not move i have test
Thank you for your message.
PNO2 refers specifically to a programming function where you can change the torque of the motor, presumably this has been set too full while conducting tests to ensure that resistance is not an issue.
This could potentially be a safety input causing this fault as it seems random, although it could be the control board not giving out the voltage.
I would link 18,19,20 back to terminal 25 to ensure that there are no safety inputs that can be causing any issues while testing.
I presume that you have used a battery to move the motors manually to test they both work, however when you give a command have you metered out that motors voltage output to ensure there is voltage coming out?
Another method for this is to swap the motor one connections with the motor two connections in the control board and see if the fault stays with the same motor or swaps onto the other motor, if the fault switches to the other motor this could prove that it is a board related issue.
I hope the above helps.
  Beninca BOB30ME - Not closing all the way OMH 1 541 09-01-2026, 09:54 AM
  Beninca TOM4024E wiring Shropshire_Lad 1 2,261 14-07-2025, 01:59 PM
  Beninca du.it14n Parko 1 4,412 24-08-2023, 01:38 PM
  Beninca bob motor wiring to board Ranch2 6 13,614 18-11-2022, 09:59 AM
  Beninca BOB21m Photo cell issue Rossm1987 1 7,813 02-05-2021, 12:39 PM
Last Post: Rossm1987
  Beninca motor capacitor ? OferD 0 5,397 22-02-2021, 06:02 PM
Last Post: OferD
  Beninca Bob Noisy johnthecandle 0 6,820 19-11-2020, 11:43 PM
Last Post: johnthecandle
  Beninca RI 6E Problem leonardermo 0 6,427 29-04-2020, 08:45 PM
Last Post: leonardermo
  one gate not moving tef 0 8,021 03-05-2015, 04:50 PM
Last Post: tef
Sad Problem with Beninca R1.6E TerryDorset 2 22,358 04-04-2014, 04:50 PM
Last Post: TerryDorset
