  • 6 Vote(s) - 3.17 Average
Came ZM3E - Wont open from keypad
I have a Came ZM3E which is working fine from all the remote fobs and the sub ground pressure plate, happy days you would think!
However, when I key in the previously working 4-digit gate code from the Came BPT Targha entry system, it beeps and then lights the amber warning light.
I’ve tried the usual power on / power off to no avail. The gate code hasn’t been changed, and I don’t touch the internals of the ZM3E.
Does anyone know if there is any way I can check an error code to troubleshoot this please ? Is it possible that the gate code has reset to system defaults ?
Just seems odd its working fine in all other situations, it just wont open from the keypad.
Many thanks for any help!
It may be possible to find a reset. What's the model number of the keypad?
Prem
Thanks for getting back to me.
Its is a  BPT HSC-1ST 1-Button Surface Targha Audio Entry Panel
ADI#: HSC/1ST
Model#: HSC/1ST
  ZM3E underground loop problem GhostUK 4 13,205 20-03-2024, 10:46 AM
  Came FROG-A + ZA3 controller > gates wont close safety beam endam 6 18,045 23-02-2023, 01:09 PM
  My Came ZM3E gates won’t open golfnut75 1 11,025 12-08-2022, 08:40 AM
  Came FROG - one leaf occasionally does not open fezster 3 13,285 03-08-2021, 10:07 AM
  CAME ZM3E Mike2006 0 13,835 28-09-2020, 07:48 PM
Last Post: Mike2006
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,647 02-05-2018, 06:18 PM
  Came ZM3E and Frog Motors both opening on M1 not seperately giuseppem 1 18,808 11-04-2018, 07:25 AM
  Frog - ZA3: gates won't open BarryD 0 12,101 15-06-2016, 01:34 PM
Last Post: BarryD
  CAME double gates - one side closes but will not open crliving 1 21,704 02-08-2013, 09:39 AM
Last Post: Blakey111
Shy CAME S5000 Keypad - Changing Code 1 36,219 11-01-2011, 04:55 PM
