  • 46 Vote(s) - 2.83 Average
#31
Hi guys,
I was wondering how the diagram would look like if you have 2 Nice gate motor on the DS-KD8003.
I am trying to get two gates running  Sad
Could somebody tell me how to set this up with only 1 COM port on de Hikvision.
Thanks in advance
(10-10-2022, 09:58 AM)j1000 Wrote: Hi Joe,
Appreciate any advice.
Thank you for coming back to us on this.
I would try firstly getting the fault to occur again, as soon as the fault occurs due to it being a time sensitive thing have a look at the control board inside your motor.
There will be a terminal block labelled as BUS, BlueBus or ECSBUS. Behind that terminal there will be an LED flashing, under fault conditions the LED will flash a certain amount of times and pause for one second, could you let me know how many times your LED flashes as this could give us some indication of what the panel may be suggesting the fault is.
  Gate transmitters intermittently working Nice MC824H solihul 0 82 19-01-2026, 10:22 PM
Last Post: solihul
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 1,064 09-01-2026, 10:38 AM
  Help me identify this mystery gate opener alpha 5 6,086 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,663 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,689 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 5,227 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,721 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,362 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 14,553 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,384 16-11-2024, 09:25 PM
Last Post: thronetm
