  • 21 Vote(s) - 3.62 Average
BFT Thalia “bAr” error.
Hi, my BFT Phobos arms, Thalia unit won’t open or close. I have looked on the control board and the LCD screen reads “bAr”.
I’ve checked the wiring by eye of the safety bars and they seem connected as they have been with no breaks. Furthermore, I can’t see any obstructions.
I really can’t afford to get an engineer out at the moment. Are there some things I can try to fix it?
Thank you
(16-01-2025, 04:00 PM)Joel23M Wrote: Hi, my BFT Phobos arms, Thalia unit won’t open or close. I have looked on the control board and the LCD screen reads “bAr”.
Thank you
Are the safety edges wired directly into the board? If so have you checked for resistance on the safety edge. You should be getting roughly 8.2 Ohms.
Jake
  Thalia P - BAR error devsolo 3 17,666 03-02-2025, 09:57 AM
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,185 26-09-2023, 05:32 AM
Last Post: max666
  Proteco Q60 - FH error then close after opening Needlerp 1 5,742 24-06-2022, 09:54 AM
  Deimos BT 400/600 error codes orange 0 5,879 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,085 02-09-2020, 07:06 PM
Last Post: Adam67
  Re: Error 30 tony.jay8 2 14,672 10-05-2018, 11:17 PM
Last Post: tony.jay8
  BFT Error 35 & 37 Not opening fully - SOLVED razer raz 4 50,868 14-11-2017, 04:02 PM
Last Post: razer raz
  Q60A/R error. Showing "_ " Jonas Pistolas 4 23,974 03-11-2017, 10:19 AM
Last Post: Jonas Pistolas
Question Proteco q80s Error 44 Cphats 1 12,305 13-08-2017, 11:15 PM
Last Post: gerardo
  BFT Deimos BT Error Codes rajesh 1 21,066 05-06-2017, 11:07 AM
