  • 21 Vote(s) - 2.86 Average
Question BFT Deimos A400
Hoping someone can assist.
I have a Meross Garage Opener which works on my BFT Deimos BT A400 when power is supplied via a power outlet externally.
However, when I use terminal 50 and 51 to convert the 24V to 5V for my USB outlet power, the Meross doesn't power up.
Terminal 60 & 61 works fine for signal (common) (start), but as soon as I try to plug into my step down converter no power goes to it.
Am I doing something wrong? Any advice appreciated.
Please see images attached.
TIA
Hi did you ever get this working? I have the same issue. How did you power the meross opener?
(15-05-2024, 08:05 AM)Makaroni Wrote: Hi,
TIA
Hey I found this thread as I'm having the same issue, purchased pretty much identical converter and not working, instruction manual is unclear. However what I discovered by a volt meter is, its 24V AC !! NOT DC !! OMG !  so you need to buy a 24V AC to 5V 1a or 2amp DC converter, I can't guarantee it works,  as I'm returning Amazon DC/DC converter and just ordered a new AC/DC converter from Amazon not arrived yet. I'm not sure if I will remember to report it here but give it a try.
Good luck.
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 5,393 15-10-2024, 10:37 AM
Last Post: Sootylfc
  bft deimos ultra bt600 error f1 pfloyd 4 8,433 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 15,512 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 4,272 05-03-2024, 04:17 PM
  BFT Deimos Ultra remote problems shaggy 1 14,850 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 10,214 30-04-2019, 09:32 AM
Last Post: ok.dude
  BFT Deimos - How to fit a GSM Switch. MyGatesDontWorkSoGood 0 8,397 02-06-2018, 04:46 PM
Last Post: MyGatesDontWorkSoGood
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 20,186 23-12-2017, 05:38 AM
Last Post: TAOZ
  BFT Deimos gate won't close Arthur_k99 15 100,108 03-07-2017, 02:58 PM
Last Post: Arthur_k99
