  • 19 Vote(s) - 2.47 Average
Trouble accessing ZLJ24 Control Panel Box
Hi there! I need to access my ZLJ24 control panel but am having huge problems removing the cover of the control panel box. I have unscrewed the 4 screws (circled in red in the image) however the cover does not want to budge. Is there a trick to opening it? Are there any clips or latches I need to additionally unfasten? I have run my fingers all around and had a good look but can't seem to find anything else requiring unfastening. Am not sure if the installers applied any form of adhesive to the box lid. Any help is greatly appreciated!
(02-10-2024, 10:25 AM)chich Wrote: Hi there! I need to access my ZLJ24 control panel but am having huge problems removing the cover of the control panel box. I have unscrewed the 4 screws (circled in red in the image) however the cover does not want to budge. Is there a trick to opening it? Are there any clips or latches I need to additionally unfasten? I have run my fingers all around and had a good look but can't seem to find anything else requiring unfastening. Am not sure if the installers applied any form of adhesive to the box lid. Any help is greatly appreciated!
The ZLJ24 does not have any additional catches, if all the screws are completely unscrewed I cannot see why it would not be opening unless some form of sealant has been used.
Jake
Hi Jake, thanks for the response. Do you have any ideas on how to potentially remove or undo the sealant? The case is completely shut and I don't want to have to break or cut it open. Thanks.
  Came ZA4 control panel Pat 2 5,668 09-05-2025, 12:30 PM
  ZLJ24 and AXO Motors gone awry colmgillard 1 5,139 22-04-2025, 08:19 PM
Last Post: Mibbo
  Came ZA3 Control panel wiring help and setting up help 7 56,536 24-09-2024, 03:29 PM
Last Post: merefield
  CAME ZLJ24 Control Panel SmtsFnd 5 11,953 08-05-2024, 08:57 AM
  ZLJ24 Reversed Paulgates 1 5,285 15-04-2024, 12:05 PM
  Came ZLJ24 Lyneve 1 7,463 16-07-2021, 12:35 PM
  Help with intercom to Came ZLJ24 paulaj 0 7,486 15-06-2020, 06:27 PM
Last Post: paulaj
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 22,640 02-05-2018, 06:18 PM
  Came ZA3 Control panel - Green LED Flashing BarryD 0 15,910 18-07-2016, 11:19 AM
Last Post: BarryD
  Came za3 control board and mag-lock? Erjujo 3 34,825 10-12-2013, 10:16 AM
Last Post: Blakey111
