  • 23 Vote(s) - 2.96 Average
Nice robus not closing
Any help would be great
I have a nice robus that won’t close
It seems like the photocells as it clicks when pressing remote and if I close gate manually it opens
 How do I disconnect photocells to test if it’s them ,
I believe I have to bridge some wires but not sure which ones
Cheers
Hi Dantay,
First of all, I would get this fault to happen again and following this, have a look at the BUS LED which is a diagnostic. You would need to count how many flashes there is before there is a pause, you can then refer to the diagnostic codes in the manual or you can let me know. If the LED is flashing once per second, this indicates no issue.
To test without photocells you would need to remove the cables going into CLOSE and put a link between those two terminals in CLOSE.
I hope this was useful.
Many Thanks
Aiden
  Nice gates don’t close after the ambient temp is high Howard 2 8,369 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 4,053 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,726 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,833 09-05-2025, 01:07 PM
Last Post: gatekeeper
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,932 10-12-2024, 11:29 AM
Last Post: dmrgate
