  • 17 Vote(s) - 3.24 Average
FAAC problem
I have a newer FAAC control box, and using 400 series 220v actuators. when i activate the dual gates, they both open about 20% and then they close and the motors keep running. I do not have any safety features, no photo sensors , no other options or accessorizes .
I have tried the learning process and nothing seems to correct this. There is no binding or obstructions on the gates, i even unhooked them and tried to run the actuators unattached.
I hooked up the actuators to my test bench switch and they both work perfectly.
they are set at maximum torque. any suggestions?
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 4,814 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,149 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,910 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,789 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,640 18-11-2024, 11:48 AM
Last Post: robhight
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,114 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 6,940 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,623 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,414 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 11,915 21-11-2022, 09:54 AM
