  • 17 Vote(s) - 2.65 Average
Nice MC800 Wiring issue
HI All
I'm hoping you can help, I have had a issue with my MC800 unit and read the manual and decided to do the silly thing and factory reset the unit. all seems fine until i pressed the fob to open the gate. the gates will not open and its down to the unit needs reprogramming.
The issue im facing is the engineer has install a photo in the closed terminal, and the closed led is always on.
if i remove the photo cell the gates work, it was install and working before i reset the unit.
what setting in the config do i need to change to get this working,
The process i had or im hoping to have is.
1. press button gates start to open ( done )
2. gates keep open for 5 seconds. (done )
3. gates starts to close one gate closed slower ( wind issues ). ( think i have done not sure )
4. if one of two photocell are broken or the bump bar is hit stop the gates and reset to open (  hold for 5 seconds the start to close again ). ( i believe this is done already buy jumpers ? )
5. gates closes locks magnet. ( not done )
(see the image )
thanks for any advice
Adamzsite
Hi All
I have found and fixed the issues,
The issues was our bump bar ? still have to replace this or fix. but i have just disconnected for quick fix.
Editing the NICE controller i have setup the system up.
Adam
If you have any issues in the future, please call through to Easygates Ltd on 01384569942
We are experts on Nice products.
Mike
  Nice Control unit passcode removal Andruelectricgates 1 4,051 17-06-2025, 11:25 AM
Last Post: HarrisonN
  MC800 NOT OPENING FOR WHITELISTED PLATES AFTER FACTORY RESET Wenzo 4 4,101 27-05-2025, 09:09 AM
  NICE gates open slightly then stuck Overthefence 2 4,726 21-05-2025, 10:54 AM
Last Post: gatekeeper
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,930 10-12-2024, 11:29 AM
