  • 15 Vote(s) - 2.6 Average
Electric Gates with AllMatic BIOS2 Unit
Hi there, totally new to this.
Yesterday, i opened my electric gates with the keyfob in the usual way however, they have not closed and seem stuck open.
The AllMatic unit is powered up, i can hear the click when i press the fob.  Photocells appear to be working as the light comes on when you break the beam.
Any ideas as to what can be causing the issue?  Display on the BIOS2 Control unit shows -tc (which is Automation opened with auto reclosing) but this isnt being replaced by the closing countdown.
UPDATE... have been out and disabled the switches in the board for the photocells and now can open and close! only thing is that the photocells are now not doing anything. Can only assume its an issue with the photocells causing the original problem?
(19-01-2024, 01:29 PM)antsnaith Wrote: UPDATE... have been out and disabled the switches in the board for the photocells and now can open and close! only thing is that the photocells are now not doing anything.  Can only assume its an issue with the photocells causing the original problem?
I would try personally reimplementing the photocells how they were again and double checking the fault displayed on the LCD display to confirm what the fault is.
https://www.allmatic.com/wp-content/uplo...-BIOS2.pdf
Welcome! It sounds like your gates might be stuck in the automation opened mode. Check for any obstacles along the gate's path. If all seems clear, try resetting the system or contacting AllMatic support for specific guidance. The -tc on the BIOS2 Control unit suggests the automation opened with auto reclosing, but the closing countdown isn't triggering. Troubleshooting step-by-step with AllMatic's support can help resolve the issue
  Gates not staying open JimM169 1 2,608 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,305 21-08-2024, 12:21 PM
Last Post: TheDock
  Allmatic Bios2 - Unlock Automotion User1459 1 2,937 19-07-2024, 09:11 AM
  Rigel 5 , gates won't open Nameloc 4 9,921 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 5,880 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 2,913 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Came gates za3p Webby 4 14,706 07-01-2024, 07:11 PM
Last Post: Simon NW
  Nice Gates not closing StuL 1 7,891 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,368 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,791 25-05-2023, 03:55 PM
Last Post: Kaala1
