  • 15 Vote(s) - 2.73 Average
Genius JA592 issue
Hi all, hopefully somebody here can help me out.
so, recently this gate board has been giving a few issues, wheras it doesnt close fully.
I know to press the f button for 3 seconds to re program the sequence of open/close, however when i press this button, both gates open, it does not seem to be giving me the option of holding for 3 seconds. the moment i press button, both gates move open at the same time
I am sure this used to, as i reprogrammed it recently with new motors.
if the board is at fault, i have no problem replacing it, but would like to see if anybody here had a similar issue before.
thanks a lot in advance
edit: ds1 switch positions are
1 off
2 off
3 off
4 off
5 off
6 off
7 off
8 on
9 off
10 off
11 on
12 off
Thank you for your enquiry.
Could you please confirm if there are any accessories wired into the panel, if so what accessories have you got wired in at the moment where the fault is still present. Sometimes we tend to find that it is an accessory throwing up strange faults on these control boards even though the accessory itself may behaving correctly.
I would suggest if you have got anything wired in to remove it and link out your safety connections to ensure you can operate the gate fully open and fully closed.
Hi, thanks for your reply.
the only things extra that are connected are the photocells and keypad.
so i should disconnect these and see then if the board is working correctly?
That is correct. Just leave the motors connected to the board.
Easygates Ltd
  BFT Demios A600 bAr issue Rohbot15 2 2,097 15-08-2025, 01:41 PM
  BFT Deimos issue erickavo 2 3,104 09-07-2025, 11:34 AM
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 5,928 25-05-2023, 03:55 PM
Last Post: Kaala1
  BFT IGEA BT issue warren5 1 5,781 13-04-2022, 11:49 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,612 02-05-2021, 09:00 PM
Last Post: soother
  Beninca BOB21m Photo cell issue Rossm1987 1 7,813 02-05-2021, 12:39 PM
Last Post: Rossm1987
  BFT C130 Photocell Issue labbetts 0 5,984 25-01-2020, 05:01 PM
Last Post: labbetts
  BFT DEIMOS BT Programming issue dawoodejaz@hotmail.com 0 6,538 28-11-2019, 12:11 AM
  Genius Gate System Problem grasshopper 1 14,825 01-07-2019, 09:39 AM
  Genius JA574 problem jeeter 0 6,745 02-05-2019, 01:13 PM
Last Post: jeeter
