  • 94 Vote(s) - 2.8 Average
Came gates za3p
Hi.  New here.  I have just installed my new gates   The program is flashing on pcb board   I have fitted radio frequency board  but I don’t have any photo cells how do I short out them ? Thanks in advance
2-1 / 2-c1/ 2-cx /
there are three NC contact bridge them up
Best Regards
Tom
ZA3P Blew with a slug dancing across the board. Replaced with a brand new one and worked for 2 days then was tripping RCD in house. Removed board, no slug / insect, checked all wiring but keeps tripping RCD. Board has a Remootio 3 attached for wifi gate opening and lights that come on for 10 mins after gate activation. 2 arm gates ATS30 - any ideas?
Tested capacitors in arms, only thing I can think of is limit switch in arms was knackered by gate installer ~ 1 year ago - could the fault be with the arm?
Hi Simon
I would suggest disconnecting all accessories from the board and run 1 motor at a time. This would determine whether it is a motor issue or a control board issue as i doubt both motors would cause the RCD to trip.
Easygates 1
(04-01-2024, 10:12 AM)Michael Wrote: Hi Simon
Easygates 1
It was the courtesy light(s) - new bulbs purchased, reconnected, blew again so no lights.
Different issue - limit switches are off on the board, but now left hand gate will open, but not close. I am guessing the Limit switch in the ATS30 is knackered (like the right hand gate is)?
  Gates not staying open JimM169 1 2,477 21-05-2025, 02:55 PM
  FAAC gates out of sync TheDock 1 3,175 21-08-2024, 12:21 PM
Last Post: TheDock
  Rigel 5 , gates won't open Nameloc 4 9,636 04-05-2024, 12:41 PM
Last Post: Alee
  Gates tripped Phil.c 3 5,642 01-05-2024, 09:34 AM
Last Post: Phil.c
  Came ZA3 gates stuck open Ivorwindybottom 0 2,798 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 7,554 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Nice Gates not closing StuL 1 7,646 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 15,128 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Came gates stuck open. Ring8180 7 29,368 23-02-2023, 01:08 PM
  Aria 400 - gates keep opening and closing objohnuk 1 7,783 13-04-2022, 11:32 AM
